electrical problem
Old Nov 19, 2006 | 10:40 AM
andy8's Avatar
Default electrical problem
ive replaced the horns on my 76 250 ce,no problem.im trying to put them on my harley,ive connected 1 wire to earth the other to live,nothing.any ideas?
Old Nov 19, 2006 | 05:23 PM
sleepwalker's Avatar
Default RE: electrical problem
[sm=smiley13.gif] no idea.
Old Nov 22, 2006 | 12:18 AM
otm646's Avatar
hmm did you check the polarity of each lead, positive or negative? if they are switched you might get nothing. try the horn on an external source, directly to the battery or a 12v powersupply,make certan that your fused connection is ok. you can visualy inspect the fuse or use an ohm meter. if you get very high resistance or infinite resistance the fuse is blown. check the wire you are using for problems by using the same method of going from negative on the battery to the negative lead for your horn, do the same for positive. remember to disconect power or you risk damaging your ohm meter. check the horn switch if the horn works wired directly to a 12v source.
kurnia.2
Feb 11, 2015 03:43 AM
4XXXX
Sep 1, 2008 01:52 AM
and42is
Aug 16, 2005 10:33 PM
rifle
Dec 5, 2004 07:03 AM
