300D primer lift pump
My lift pump has a crack in the housing on my 617 turbo diesel and leaks oil from the IP.
Question : Has anyone installed an in line 12v delivery pump to supply the IP and just put a plate with gasket over the hole in the IP? If so, what PSI and gallons per minute pre pump would the IP require?
Thanks MM
Thanks MM
