300 SE Gearbox
Old Jul 16, 2005 | 12:46 PM
KARR 300's Avatar
Default 300 SE Gearbox
my 300 SE s a automatic transmission, i found it was leaking fluid at 1 time,where in panic from preventing it from ceasing i put in more than required to top it up.In due time i had the gearbox replaced and the seals changed by a mercedes specialist. once again the car was in tip top shape,until i started finding some drops of transmisssion fluid on the brick work of my driveway. i took it to the specialist on few occasions he said he cud`nt see a thing., eventually whilst coming home the car feels more heavier than it actually was, i find i have to keep my foot on the accelerator to keep the car from slowing down, and if i let go off the pedal the car slows downn really really fassst. can any 1 help here once again ? i took it to hhim and told him the problem, he said its the fuel filter, i had the fuel filter replaced with a so-called other part which it came with but still no -joy! , my own guess is ... i took a look at the rod dipstick inside the enginebay which goes towards the gearbox fluid check. Is it because hes put too much in the gearbox? it looks waay toooo much over the markings .
Old Jul 16, 2005 | 01:01 PM
sleepwalker's Avatar
Default RE: 300 SE Gearbox
was it a heavy leak?
can you see the source if you lift up the car?
have you tried removing all the fluid and just fill the specified amount... or measure the drained oil?
it's hard to make a guess for me.
orgelartes
Sep 23, 2007 09:36 PM
gugufut3
Jul 3, 2007 11:32 AM
Davidoff
Aug 19, 2006 08:27 AM
christina1939
Dec 11, 2003 06:55 AM
jocor
Nov 19, 2003 07:21 AM
