207D start problems
Old Nov 24, 2011 | 10:51 AM
basvossen's Avatar
Default 207D start problems
hi, I've got a 1980 MB 207d camper. It's got a newer Tausch engine, from a G-model.
Now it wont start, it started yesterday after sitting for 2 years. I bought a new battery.
I can't find the starter solenoid.
Hope you can help me out :-)
cheers,
Bas
Old Jun 21, 2023 | 09:01 AM
Mattymotorhome's Avatar
Default Vacuum start?
Hi Bas, have a look at the fuel system, my 207D is a slightly newer 1983, and has vacuum only system, no solenoid, vacuum pipe runs from ignition to a vacuum operated cut off valve that lifts to allow fuel to engine, if your starter is cranking engine over, then vacuum cut off is a good place to start, hope this helps, when my engine runs sluggish I often find the valve sticking a bit, and fuel delivery gets restricted, also you may need to prime the engine first, little white dial next to above said valve, pump a few times until you see no air bubbles in fuel pipe. Good luck
sacredsilence
Feb 16, 2013 08:54 PM
Cypressfriar
Sep 29, 2010 01:49 PM
cici235
Sep 16, 2010 09:19 AM
silverhalide1
Jul 21, 2008 02:44 PM
mr2by4
May 3, 2008 09:41 PM
