2001 s430 dash light out
Old Jun 6, 2015 | 11:56 PM
dgbourne's Avatar
Default 2001 s430 dash light out
my 2001 s430 dash light(s) went out suddenly. All gauges and instruments are working fine. No malfunction is displayed. I cheked fuse and it is okay. I did replace it and nothing changed. Also on fuse map, instrument cluster states 3 fuses: f20,f21,f22 5 amp each, but in fuse box only one fuse in f21 slot, other two are empty. Any suggestions on what to do? Thanks
Old Jun 7, 2015 | 05:19 AM
dreamer no2's Avatar
Hi dgbourne you need a wireing diagram .I think you may just have a instrument cluster relay box in some place . It may be at the rear of the speedo head. I see if i can find more for you.
Old Jun 7, 2015 | 05:40 AM
Hi the check i have done was helpful to say .That 4 years ago Mercedes did a recall on this problem ,reason is a faulty cluster .And they told the owner to get in touch with M/B for a replacement .So do a check on recals on your car and see if it was right.
Old Jun 7, 2015 | 05:53 AM
DG got it .Can you use the GOOGLE SEARCH ENGINE ? if so go to the site and in the search box put in FUSES AND RELAY LOCATIONS DESIGNATIONS S CLASS CL CLASS .. Just been in and i can see you have 3 fuses for the instrument cluster . Check it out its very useful.Please let us know .
Old Jun 8, 2015 | 10:14 AM
dgbourne's Avatar
Thanks dreamer, I will check it all out. I see the recall so will contact MB and see if they will honour it. I will keep you informed.
Old Jun 9, 2015 | 05:03 PM
dgbourne's Avatar
Thanks for the information, I have almost exhausted my research into this. The recall did not affect my MB because of the VIN not being part of it. This is from MB both in the USA and Canada. The part in Canada is $2073 with an additional $180 to ensure it is coded or synchronized with old dashboard cluster. I am looking into an LED refit on it that I found through YouTube, but again it is in the US and must ship the dashboard cluster there first. So that may not happen.
Know anyone interested in a 2001 S430 in good running condition but without dashboard illumination?
Old Jun 10, 2015 | 03:55 AM
Could it be your rheostat .A small adjuster for you dash board lighting .What other items are not working in there?
Old Jun 10, 2015 | 04:16 AM
This is a rheostat ot petentiometer for better word .It turns up and down you dash lights . You will have to check if you have this adjustment **** in the console to sdjust you cluster lights. On my car its also for adjusting the oddometer .It some times works, and more than not, it wont .If you have this said **** dont go mad with it as it adjusts the oddometer and can end up with more problems. The dash will need removing i would do this anyway to find the problem ,could be a plug thats come out .I will have a fuse on there as well and a relay. You may not have this pentiometer on your oddometer i dont know.
Old Jun 10, 2015 | 04:57 AM
  #9
DG check this out .Can you go to Google Search put in ----
2000 S430 Insrtrument Cluster Mercedes .Benz Forum - Ben A lot of nformation that could help you to get it replaced free. I dont think info i left before will apply to your console.
Old Jun 10, 2015 | 05:19 AM
  #10
Also google again No Dash Light On My Mercedes S 430. On this one he pulled his and had a rebuild. Another said water can get in through the vents under the front window .With the bonnet up you will see a wafle grill by the wipers under it sits a funnel that gets blocked with debris ,this lifts out, but be carefull not to brake it .Clean out the rubbish in there.If the water gets in it can damage a lot of electrical items inside the car dashboard .
