1993 190E
My 1993 190E 2.6 has oil in the coolant. It also leaks oil from the front of the engine. Can someone help me out with a little history on these engines. Are they prone to head gasket failure, warped heads, cracked heads, all of the above? If you have any experience with this problem, I would appreciate your advice. PLEASE HELP!! Thanks
I have a 300e an 190 the 300 i just did a head gasket on because of oil in coolant the gasket looked good it turned out to be a warped head my macheneist sait mercedes heads where rarely cracked unless there was extreme heat. i paid 300 for the job and 45 for head gas set cheep hua. i also did a valve job with new valve seats.i have a head ready to install if you need anything call leo at 541 272 1179
dlicheri
Mar 30, 2007 09:08 AM
