1988 Mercedes 300E problems going into reverse
Old 03-28-2012, 09:15 AM
Kirk Dockum's Avatar
Default 1988 Mercedes 300E problems going into reverse
Two days ago we purchased a 1988 300E with a little over 100,000 miles. All forward gears work perfectly but when you put it into reverse, it just sits there. If you put your foot on the brake, push your foot on the accelerater to bring up RPM's, it will go into reverse and work perfectly. Is there anything controlling the vacuum or pressure to the transmission that could be causing this problem?
Kirk Dockum
03-31-2012 12:50 PM
Daviddents
05-17-2010 12:30 AM
JimMayor007
09-21-2008 01:27 AM
ddwong
11-02-2006 10:19 AM
kazooguy
09-28-2005 10:30 PM
Quick Reply: 1988 Mercedes 300E problems going into reverse
