1986 420 sel fuel pump relay????
Old Aug 13, 2008 | 04:14 PM
frankiec's Avatar
Default 1986 420 sel fuel pump relay????
where is the fuel pump relay located, and how can I test the fuel pump? thanks
Old Aug 17, 2008 | 10:44 PM
nescid's Avatar
Default RE: 1986 420 sel fuel pump relay????
The fuel pump relay is Part No. part # 003 545 25 05
I am not sure now but this should be located under the hood by the fuse boxes. If not try locating it close to the firewall under the wiper motor. It is a black box about 2.5in x 3.5 in x 1-1/4 in. There should be around 10 pins for the connector (line of 6 and a line of 4 pins). Just pull the unitup to disconnect. Let me know if you need a used one.
Thanks.
nescid
Old Aug 18, 2008 | 09:03 AM
frankiec's Avatar
I found it. it is connectect to the firewall and the demenssions are correct. This was the issue why I was not getting power to the fuel pump. The pins needed to be clean and the receiving side needed to be tightened for the module pins. Now all is fine and the motors are humming away. Thanks
Old Nov 4, 2012 | 10:49 AM
dave frazier's Avatar
Can anyone help me? 1987 420sel with the Bosch intake. No fuel to the engine. I have already changed the fuel filter and removed the relay and jumered #7 and #8 sockets. I can hear the pumps come on while standing at the engine compartment, I also felt them as well. Still no gas to the engine (pulled gas supply line at intake to veiw) Cranking or not still no gas?
dado1968
Apr 27, 2012 01:34 AM
walt12
Jun 9, 2006 09:16 PM
cepope99
Mar 30, 2005 04:41 PM
Randy
Mar 15, 2004 01:17 PM
Randy
Mar 7, 2004 12:35 AM
