1985 sl 380 wont start
Old Jul 7, 2016 | 04:01 PM
tony92124's Avatar
Default 1985 sl 380 wont start
My 380 has been siting for about 6-7m months battery disconnected ran fine started right up...tried to start it wont start. used gas in carb and fuel start kicks over but dies , as soon as fuel runs out what is the problem ?? how hard is it to change fuel pump and filter??
Old Jul 11, 2016 | 12:11 PM
daemdaem's Avatar
Hello, Most modern automobiles use a electric fuel pump. They almost all are inside the fuel tank to help keep them cool, however some are external.Further most are powered through a relay. This is a anti theft and crash safety feature. To hold the relay in the on position, usually you must have oil pressure, plus a signal from the ignition key switch. Fairly often a failing key switch is the real issue. You will need to do some basic trouble shooting to determine if in fact your pump is the issue before we can help you Allan
katz1002
Jul 9, 2008 10:00 PM
rvc2356
May 24, 2008 04:39 PM
alex95060
Jan 6, 2008 06:04 PM
Vincent
Jun 13, 2007 08:39 AM
aupaul
Jan 10, 2005 11:32 PM
