1984 Mercedes 300SD Power Antenna Problem
Old Jan 13, 2010 | 05:47 PM
gdavis1955's Avatar
Smile 1984 Mercedes 300SD Power Antenna Problem
I am new to the forum but I have some information that may be helpful to those with my year 300SD who find they have a need for a pinout for the power antenna connection when troubleshooting. I could not find this information online so now that I have figured it out, I am sharing it. On a working system, when the antenna is in the lowered position, check to see if you have the following conditions met for a starting point:
1. +12 V at the BLUE (Power Antenna) wire connected to radio.
2. The dashboard power antenna switch is in the UP position.
3. +12 V available at what I call pin 1 of the power antenna motor connection located on the driver's side of the trunk.
4. GROUND (Battery -) at what I call pin 3 at the power antenna motor connection.
In order to raise the power antenna, Pin 1 must be connected to +12 Volts (Battery +), Pin 2 must be connected to +12 Volts, Pin 3 must be connected to Ground (Battery -) . Pin 4 must be zero Volts, Pin 5 must be zero Volts. In addition BLUE (Power Antenna) wire connected to the radio must be +12Volts, and Power Antenna switch on dashboard is in the UP position and the ignition key switch is in the RUN position.
To lower the power antenna, Pin 1 must be +12 Volts, Pin 2 must be zero Volts, Pin 3 must be zero Volts, Pin 4 must be +12 Volts, and Pin 5 must be +12 Volts. In addition, the BLUE (Power Antenna) wire must be zero Volts.
The reason my power antenna was not going up was my radio was not putting out the +12V signal on the blue wire due to an internal failure of the radio itself. I have temporarily fixed this problem by connecting the BLUE wire to a YELLOW (Battery +) +12V connection that powers my radio. I have a Word document and truth table showing both the way I have numbered the pins on the power antenna motor connection and what the states of these pins should be on a working antenna. Email me if you would like this information. I will be happy to send it to you ...
see photo of connector at:
http://www.facebook.com/album.php?ai...&id=1057363870
Old Jan 19, 2010 | 05:48 PM
chris110043's Avatar
Default power antenna
I bought a power antenna for a Mercedes 190 E 2.3 engine. This part had a very easy installation and i have'nt had any problems yet. I bought it from Javier, at qeautoparts.com. I recommend all you Mercedes fans get your parts there. They have a huge selection of Mercedes parts in stock. My next purchase is a pair of front axles, brake discs and brake pads. I can't wait! Good luck!
member300sd
Jul 18, 2014 12:57 AM
pekingnesepuppy
Jun 21, 2013 09:31 AM
sparkerltt
Jun 28, 2012 11:42 PM
kwake
Apr 20, 2009 07:53 AM
XautoL
Jan 28, 2009 10:01 AM
