1974450sl fuelpump/relay?
No gas to intake. Will run for 30 seconds if gas is hand poured into intake. Pulled pump and filter. No response when I applied 12v directly to pump. In addition,test light shows no current at pump+ wire with ign switch at off,on and start positions. Don't hear relay click when I turn on switch, but do hear relay static sounding clicking when I disturb fuse with ign switch at on position.Battery is fully charged. Any suggestions.
Thanks,
Dennis
Thanks,
Dennis
Try changing the fuse to illiminate a bad fuse do you know anything about removing the gas tank?thanx Gary carsmarty@gmail.com
