03 E500 Air Suspension
Old Mar 31, 2012 | 05:49 PM
ERIC WOODS's Avatar
Default 03 E500 Air Suspension
got an E500 rear l/h airbag went bad replaced both rear airbag springs new compressor & compressor relay, car will not inflate airbags or lift rear anyone ever come up with this problem in the past,dont know what to do next
Old Mar 31, 2012 | 06:12 PM
chassis221's Avatar
might have to clear codes first. might need MB computer to clear codes. and activate air suspension. can you hear the airmatic pump running?
Old Apr 1, 2012 | 03:52 PM
ERIC WOODS's Avatar
Default 03 e500 air suspension
no airmatic pump does not run something seems missing as afar as juice to power pump,can make the pump run by powering directly have checked relays & fuses we did replace the airpump relay with genuine MB part the air springs are identical to what came off it Bilstein's
arnottdoug
Apr 20, 2015 02:07 PM
arnottdoug
Apr 20, 2015 02:05 PM
HondaWhisperer
Jun 17, 2011 10:47 AM
domnvic
Jun 7, 2009 02:33 AM
Mike456
Apr 7, 2008 11:53 AM
