02 Benz c240 not shifting & ESP/abs light on
Old Jan 21, 2014 | 09:59 PM
Revolution1's Avatar
Default 02 Benz c240 not shifting & ESP/abs light on
02 Mercedes Benz c240
Rear wheel drive
Multiple issues
1. Will not engage in second gear or 3rd
2. When shifting in drives it shifts very hard
3. Speed needle remains on zero while driving
4. Trip tronic or economy more doesn't make no effects
5. Esp and abs light stays on
6. Battery is keep draining out
Task were done to repair it
Replaced transmission sealed
Replaced shift plate
It didn't fixed the issue then mechanic said I have prob with my abs pump module which is not allowing to shift
Replaced abs pump module with other old module with different id
Still no difference
New battery installed
Need help
Old Jan 22, 2014 | 06:26 PM
chassis221's Avatar
you probably have transmission fluid running up to the transmission control module.very common.transmission control module is under the passenger floor carpet. Under the metal plate.
callcoy
May 30, 2014 02:11 PM
sladedestiny
Aug 3, 2012 02:55 PM
gersmit
Jan 7, 2008 10:17 AM
