**** DOOR LOCK GOING CRAZY ****
Old Nov 28, 2006 | 12:03 PM
ggonzalez1121's Avatar
Default **** DOOR LOCK GOING CRAZY ****
Recently my door lock on the drivers side of my C240 has been going crazy.
If I try and lock the car with the key switch it will go up and down uncontrollablly. This problem just started not to long ago and I thought I would go away or fix itself, but now its just driving me crazy!!!
Any suggestions on how to fix this...or has anyone had a similar problem? Any HELP would be apprieciated....Thanks!!!
Old Nov 28, 2006 | 02:53 PM
1st lite's Avatar
Default RE: **** DOOR LOCK GOING CRAZY ****
I had the same thing with the door lock (02 C240) happen to me a few months back. Hit the remote to lock or unlock the doors, and the door lock would bounce up and down 3 or 4 times. Sometimes it wouldn't lock automatically, would have to use the manual key sometimes.
I ended up purchasing a new auto lock assembly (made by Hella) from the dealer and installed it myself. I asked one of the mechanics how long it would take and how difficult to change. You need to have some mechanical knowledge and it will take somewhere between 2-3 hours (took me a little longer). You also need to drill out some pop rivets to make the job a bit easier. The mechanism is fairly tight to remove and re-install. The pop rivets will have to be replaced when the door latch mechanism is in place. MB will also sell you the pop rivets. I'll have to admit, it was a bit fustrating at times to shoe horn that thing in and line it up. It's done and it works great!
Someone mentioned to pull up the rubber boot that slides over the door pull rod and to put some lube on the rod. You may want to try this out first. Just remove the door panel and you will see the rubber boot. Nothing to lose by trying this first.
Old Dec 4, 2006 | 01:08 PM
SpecialK's Avatar
I am having the same problem and am curious as to what you find out.
Old Mar 11, 2007 | 06:58 AM
nickknock's Avatar
I amhaving the same thing on the passangers side. I will let you know when I find out, what is going wrong with mine.
Old Mar 11, 2007 | 01:54 PM
chassis221's Avatar
the problem is the "lock actuator" or the latch in the door. replace the latch and the problem will go away. you can also try to lube the lock **** like the previous poster said. but most likely will need to replace lock.
darwin95301
Jun 22, 2008 07:39 PM
markus invictus
Oct 18, 2007 07:47 PM
ggonzalez1121
Feb 12, 2007 06:31 PM
95ee320
Dec 11, 2006 10:19 PM
SpecialK
Dec 4, 2006 01:05 PM
