wont turn off with key
Old Feb 5, 2008 | 07:41 PM
  #11
yellow240d's Avatar
Default RE: wont turn off with key
just block it off
or make sure that the line for your shutoff is hooked up, if not just jump the line to there.
Old Feb 5, 2008 | 07:53 PM
  #12
treadstone71's Avatar
I think an attempt to block this line was made by the previous ownerusing duct tape. You think this unconneted line is the culprit? I have not yet checked the vaccum valve in the ignition. I guess I need to start there.
Old Feb 5, 2008 | 08:10 PM
  #13
Not sure how well this will post. In my hand is the miscellanious line. Its about 10 inches long and ran underneath the runners. Can't find anything at that distance for plug it into.
[IMG]local://upfiles/29985/AD8361A12A8D4EAB964615315063F285.jpg[/IMG]
Old Feb 5, 2008 | 08:12 PM
  #14
Oh and the line that feeds this one (to the right by the oil filter) runs back to the firewall and to (where I'm guessing) the ignition.
Old Feb 6, 2008 | 01:09 PM
  #15
toddmarlies's Avatar
I will get into my MERCEDES repair manuels to finf out where you need to go. Wil post back later tonight around 5 pm.
Old Feb 16, 2008 | 11:46 AM
  #16
I checked the ignition. Both vaccum lines appear to be connected and in good operating condition. I have traced all other lines in the engine bay and can't find anything. I'm stumped.
Old Feb 16, 2008 | 12:45 PM
  #17
AMGMercedes's Avatar
They might be connected, but the rubber connection points may be leaking air or a unit the line goes into could be dead.
Here's a link you may find useful. I found it while trying to locate how to adjust the tranny modulator.
http://www.dieselgiant.com/mercedesv...leshooting.htm
Old Feb 16, 2008 | 01:14 PM
  #18
Thanks that was very helpful. I am now having trouble with my engine battery, or at least I think its the battery. If I jump start the car it works fine. Is there any way to tell if my battery is going bad or if its altenator?
Old Feb 16, 2008 | 05:14 PM
  #19
cycleboy's Avatar
Get the car started. With it running, remove the negative battery connection. If it dies, the sytem is not charging. This could be either the alternator or the voltage regulator.
Another way to check is to hook the voltmeter across the battery poles. When you rev the engine the volts should rise to about 14.5 and then fall again when it comes back down to idle. If they rise, that means the system is charging.
Old Feb 16, 2008 | 06:12 PM
  #20
Sweet thanks.
