window regulator removal?
Check your Visitor Messages.
I have not had the front Window Regulators out but you need to say if they are Manual or Power Window Regulators.
When you go to remove the Door Panel under the inside Door Latch Lever is a dished in piece of Plastic that needs to be pried out to expose a single Screw.
If you door has the Map Pocket at the Bottom the front part hooks into a Sheet Metal projection on the door. After you have pulled the Door Panel away around side and bottom the edges; You need to pull the Map Pocket straight up and a little forward to get it out of the projection. Then the whole Door Panel Pulls straight up if you have removed the Door Lock Push Pull Pins at the rear top.
Thanks for the reply. I got the door panel off OK . But I have power windows and have to get out the regulator to get at the motor properly. I loosened the obvious bolts holding the regulator and it is still rock solid and won't move a bit. Must be a lot more to it that is not very simple like bolts holding along the bottom of the window inside. My window is up and tight.
Ooops_240
Mar 15, 2006 09:19 PM
