E 320 rear window regulator motor
Old Mar 26, 2006 | 10:09 AM
RADMANMOOSE's Avatar
Default E 320 rear window regulator motor
My 01 e320 wagon rear window regulator broke. they sell an aftermarket one without the motor. (are aftermarkets any good?) does anyone know how to install it? I have opened the door panal on my bosses e 320 a few years ago, I just don't remember where mercedes hides the screws or if there are any tricks to it. any advice is greatley appreciated.
thanks
Old Apr 6, 2006 | 10:01 PM
nmtt92's Avatar
Default RE: E 320 rear window regulator motor
Been there, done that...not too difficult once you get your mind around how MB designed it.
The regulator is riveted into the door. To get the old one out you need a good drill bit of the right size (can't remember the size, but you can figure it out from the new rivets). The dealer has the correct rivets to use for the replacement, if I remember correctly; they are made of steel instead of aluminum in order to take the torque of the window motor.
There are four rivets to drill out and replace. The biggest gotcha is that you need a very strong rivet gun to get the new ones in, since the correct replacement rivets are so strong.
Hope this helps...good luck.
Old Apr 9, 2006 | 01:37 AM
Thank you it did help. you are right, once you understand how mercedes does it, its not that hard. i got a replacement from e-bay for $15. (new aftermarket) tip on the rivits i didn't know about it.
thanks again
DannyG63
Jun 16, 2009 09:49 AM
brento17
Feb 18, 2009 08:44 PM
louis1961
Nov 1, 2008 12:36 PM
idecelr8
Sep 28, 2008 09:34 PM
Ooops_240
Mar 15, 2006 09:19 PM
