Whirring noise from backend of '77 300D
Old Apr 10, 2007 | 07:21 PM
hawkwing3141's Avatar
Default Whirring noise from backend of '77 300D
I've been hearing a strange mechanical noise recently when the car is in first and second gears and I can't hear it after about 30 mph. To me it sounds like if you stick a playing card in the blades of a fan, and the frequency is coincident with the rpms. I ripped out the back seat and put my ear to the floor while it was doing this and it seemed to be coming from under the rear seat, perhaps more on the driver side. Someone unfamiliar with mercedes suggested maybe it was the Universal Joint but with the single-piece mercedes U-joint that seems less likely. Any ideas? I've done some repairs but am pretty much a Mercedes novice, so any help would be greatly appreciated. Thanks!
Old Apr 18, 2007 | 02:29 PM
otm646's Avatar
Default RE: Whirring noise from backend of '77 300D
does the sound change when you let off the throttle? change in turns? or any other information so i can narrow down the options.
initially i am thinking cvshaft but with more information we can pin it down easily.
Old Apr 19, 2007 | 12:18 PM
Mr.47's Avatar
HI
I too having the same problemwith my1984 SDand it makes a whirling sound,the soundchanges when the acc pedle off, do u think is the CV shaft or universal joint??? (info: SOUND STARTS AT 40MPH and FADES AT 70 MPH but still noticiable)
Thx
Old Apr 22, 2007 | 11:43 AM
Drrty240D's Avatar
Don't forget to check the rear wheel bearings. They're hearty, but they do eventually wear and could cause the kind of noise you describe.
ulysees
Oct 26, 2010 11:41 PM
ricmor
Oct 7, 2010 08:09 PM
phidelt0135
May 18, 2010 10:49 AM
GregSkidmore
Jan 23, 2010 06:03 PM
artem
Feb 25, 2004 08:57 PM
