Transmission Problems 300D
Old Oct 5, 2005 | 08:31 PM
oysterbenz's Avatar
Default Transmission Problems 300D
Can i get some advice on this problem,
Transmission shifts hard from gear to gear (automatic) sometimes not always,, i am going to check vac modulator this weekend and check vac line, however when i got under cartoday, i saw there was a plastic shield under it,, just never knew it was there,,.. Anyway,, i checked the AT fluid and it is above the line.
Is this a problem? and if so how do i drain a little bit of fluid, do i have to drop the pan or is there a drain plug,,
What else could it be?
1991 300D 2.5 automatic, 175,000 miles,
Any help would be appreciated,, a picture is worth a thousand words.
Old Oct 6, 2005 | 12:47 AM
Kajtek1's Avatar
Default RE: Transmission Problems 300D
Had the same problem with 93 model. Turned out, while changing the serpentine belt, I pulled the vacuum tubing. If I recall it, it was somewhere behind right headlight.
Anyway, that is very likely the problem. Fine shifting adjustment is done with a screw (under the cap) on left top of the transmission.
Old Oct 6, 2005 | 12:53 AM
Kajtek1's Avatar
Don't worry about too much fluid. If the transmission is really overfilled it will blow the excess at higher speed.
Old Oct 6, 2005 | 07:48 PM
oysterbenz's Avatar
thank you for your help i have found the problem,, the vacumn control valve is not sucking any vacuumn i tested the lines from the unit and get 0 inches nadda...
could it be the vacuumn amplifier or can it be an adjustment on the vacumn control valve?
I see that there is a slight twist in the body to adjust it,, is this correct. if this fails how difficult is it to change?
i have changed the fuel shut off solonoid before so hopefuly it is not as hard as this,,
thanks
richardk
Mar 16, 2006 12:41 AM
Sky44
Feb 12, 2006 09:31 PM
angelbay
Nov 12, 2005 05:15 AM
redly1
Sep 2, 2005 07:01 PM
benzboy
Oct 29, 2004 12:14 AM
