Transmission Problems 300D
Can i get some advice on this problem,
Transmission shifts hard from gear to gear (automatic) sometimes not always,, i am going to check vac modulator this weekend and check vac line, however when i got under cartoday, i saw there was a plastic shield under it,, just never knew it was there,,.. Anyway,, i checked the AT fluid and it is above the line. Is this a problem? and if so how do i drain a little bit of fluid, do i have to drop the pan or is there a drain plug,, What else could it be? 1991 300D 2.5 automatic, 175,000 miles, Any help would be appreciated,, a picture is worth a thousand words. |
RE: Transmission Problems 300D
Had the same problem with 93 model. Turned out, while changing the serpentine belt, I pulled the vacuum tubing. If I recall it, it was somewhere behind right headlight.
Anyway, that is very likely the problem. Fine shifting adjustment is done with a screw (under the cap) on left top of the transmission. |
Don't worry about too much fluid. If the transmission is really overfilled it will blow the excess at higher speed.
thank you for your help i have found the problem,, the vacumn control valve is not sucking any vacuumn i tested the lines from the unit and get 0 inches nadda...
could it be the vacuumn amplifier or can it be an adjustment on the vacumn control valve? I see that there is a slight twist in the body to adjust it,, is this correct. if this fails how difficult is it to change? i have changed the fuel shut off solonoid before so hopefuly it is not as hard as this,, thanks |
