Texas heat is melting the apoxy holding on the bumper of my 83 300D!
Old Jul 11, 2011 | 03:57 PM
JackalopeATX's Avatar
Default Texas heat is melting the apoxy holding on the bumper of my 83 300D!
Hi all,
The sweltering heat is melting the apoxy on the front bumper rubber and causing it to sag. its still being held on be the supports on the edges of the bumper but looks terrible and is getting worse the more i drive it. is there a glue i can buy at a local auto parts store to glue it back myself or is a special type used that i need to order from MB?
ALSO: is there any way to increase performance while my AC is on? its so damn hot here and when i run the ac i practically go backwards when i hit the gas at a stoplight. im also thinking about installing a K&N air filter. will this help with the issue and is it just a good idea anyway? thanks so much!
Old Jul 15, 2011 | 10:33 AM
oldrebuiltdodge's Avatar
If you want to run a K&N air filter, just pull the air filter off all together, and run without one it would be avbout the same thing, and a lot cheaper. As far as improving performance, check all of the obvious, fuel filters, air filter, grade of fuel and so on. If the engine dosen't have enough fuel, and/or can't breathe properly, it can't perform. A clean STOCK air filter is plenty adequate, after all it was designed to operate that particular engine, provided you haven't done any aftermarket modifications that would cause it to need more air than it normally would
rayhawk43
Sep 1, 2009 09:45 PM
jallen78
May 11, 2009 07:57 PM
shrowell
Nov 14, 2008 05:03 PM
massssoud
Feb 24, 2006 08:21 PM
ivanw
Aug 19, 2004 10:21 PM
