Sluggish 300SD
Old Jun 23, 2006 | 04:22 PM
merikh's Avatar
Default Sluggish 300SD
Hi to all! This is my first post to this forum.
After using an 83’ 240D for almost ten years I’ve got an 84’ 300SD. The car has an inspection sticker which expired in 1998. It make me to believe that sins it was not driven a lot. Most likely the car was poorly maintained but garaged.
Now is the problem: the car is very sluggish in acceleration. I replaced oil, changed filters, readjusted accelerator linkage – very slight improvement, if any.
I’m resisting believing that it is normal for such a heavy car. I think that something wrong with adjustments of the car and fully open to any suggestions!
Old Jun 23, 2006 | 10:27 PM
sleepwalker's Avatar
Default RE: Sluggish 300SD
fuel filter and pre-filter is new...right?
new air filter too?
accelerator linkage is good?
Old Jun 24, 2006 | 12:18 PM
timberfield's Avatar
How bad is it??? Is the turbo spinning?
My 300SD is very slow from a standstill (especially w/ the AC on), but then gets going pretty good. However it's very sluggish on a cold start below about 40 degrees. I think it's because the oil is thick and not allowing my old, tired out turbo to spool up.
My thought was, if your car was sitting for a long time, maybe the turbo has frozen.....
Old Jun 24, 2006 | 09:24 PM
merikh's Avatar
Thanks to all.
All filters are new. Turbo spins ok.
I'm still going to check and adjust timing of fuel if needed.
By the way I never was able to force the "drop per second". I'm using method known for years:
Connect a glass tube to first cylinder and check the level.
It worked for me.
Old Jun 24, 2006 | 09:42 PM
merikh's Avatar
Dear Timberfield
"My 300SD is very slow from a standstill (especially w/ the AC on), but then gets going pretty good. However it's very sluggish on a cold start below about 40 degrees. I think it's because the oil is thick and not allowing my old, tired out turbo to spool up."
Compere your 240D with your 300SD... (Mine is a lot better). It shold not be so dumb... Something is wrong with the 300SD. I don't know what and I'm going to figure it out.
With your help!
Old Jul 19, 2006 | 01:33 PM
merikh's Avatar
I've got a manometer and the mesurement of turbo output shows a round zero and the plug for connecting manometer has traces of burned fuel on it.
Is anybody taken appart the turbo and has suggestion of how make it easyest way?
daveball
Jul 7, 2005 11:33 AM
muso58
May 21, 2005 11:58 AM
muso58
Mar 12, 2005 01:53 PM
moonbike
Oct 24, 2004 02:13 PM
stechad
Feb 14, 2004 07:22 AM
