running bad
Old 05-19-2010 | 10:14 PM
faria917's Avatar
Default running bad
hey guys I am new here, I am having problem with my 1984 300 d turbo, when I start the car it runs smoote but when I shift to drive the first two gears is fine and them the car seems like is something hold and you can give gas and nothing heppens, it doesn`t go over 30 miles.
Old 05-20-2010 | 08:33 AM
cycleboy's Avatar
Tune it up: new fuel filters, air filter, valve adjustment, oil change, etc.
Old 05-24-2010 | 10:22 PM
pottzie's Avatar
I'm having the same problem, came to the forum for input. I have a clear plastic hose for the return fuel line. I'm getting air bubbles, so I know that I've got an air leak somewhere. Tightened up every hose clamp I could get to, found a few loose. Runs better, but still won't rev past approx. 3/4 throttle. Bubbles are now less, but still seeing them. Diesels and air in the fuel don't mix.
rwogs
02-13-2011 10:04 PM
supersonic1903
06-28-2009 09:54 AM
2002MBE430
04-20-2008 06:12 PM
icanraceit
05-28-2007 07:00 PM
guycapone
11-28-2006 08:18 PM
