Roof won't close
Old Feb 10, 2006 | 03:31 AM
smithgerry's Avatar
Default Roof won't close
I have an 85 300D Turbo Sedan. The sunroof has never opened, but I can hear the motor. There is a grinding noise above my head, almost like some gear is stripped or jumping off the track. The other day, I hit the button, meaning to hit the rear defroster, and it opened slightly. Now, I cant get it to shut the whole way. It does not leak (I used a hose to see) but from the outside you can see that it is not completely closed.
I really dont care if it works, but I want it closed the whole way, can I push it closed or something? Do I have to take the whole roof liner out and actually fix it to make it close? I would hate to spend huge bucks to get it to shut.
Old Feb 15, 2006 | 05:42 PM
norml4life's Avatar
Default RE: Roof won't close
In the trunk on the drivers side there is a manual way to shut the roof using a socket set. At least thats where mine is in my 1981
Old Feb 16, 2006 | 06:26 AM
dondas's Avatar
If you had a grinding noise in the roof near the opening, then you may not be able to shut it using the emergency method, but it is most definately worth a try. If it doesn't work you may have to open it further to remove the inner lining and see what has happened.
miishmiish
Jul 26, 2022 05:31 PM
Wiz
Apr 8, 2009 12:44 PM
smithgerry
Feb 17, 2006 08:28 PM
smithgerry
Feb 10, 2006 04:44 PM
boman49
Apr 16, 2005 02:24 AM
