Primer Pump
Old May 18, 2008 | 08:51 AM
benzman83's Avatar
Default Primer Pump
I have gained much info on this forum now I need a question answered please about my 83 300D.My primer pump is leaking. How do you go about repairing it or removing it. Is there arepair kit. Thanks
Old May 21, 2008 | 09:22 AM
paddo's Avatar
Default RE: Primer Pump
I read recently that the new style is not suitable for veggie oil and other thicker fuels.
________
LEXUS GS SPECIFICATIONS
Old May 22, 2008 | 01:18 AM
paddo's Avatar
It was dieselgiant.com - I just checked. the old style is also quite a lot cheaper. I like the way it can be locked down also (mine leaks a bit when pumping but not when screwed down), not sure if the new version can do that.
________
Anemia advice
Old May 22, 2008 | 12:27 PM
paddo's Avatar
ORIGINAL: ForcedInduction
Being able to lock down has no real function other than personal preference.
The new version is spring return so all you have to do is push it.
That means its bad. If fuel can leak out, air can leak in.
When I lock it down it doesn't leak fuel or air. How do yo know the screw down has no function? It makes sense that there would be an over-riding seal in screw-down position.
________
Ram 50
Old May 22, 2008 | 06:09 PM
paddo's Avatar
ORIGINAL: paddo
Because the new style is spring return.
??? I was talking about the old style, not the new style. Don't worry about it...
________
Extreme q
boone
Aug 25, 2012 04:53 PM
seadog
Apr 6, 2011 03:11 PM
Micah
Oct 8, 2010 03:09 PM
paddo
Jul 4, 2009 03:34 PM
srishell14
Apr 16, 2007 01:30 AM
