om617 crank pulley removal Help
Old Jun 13, 2011 | 01:02 PM
ruddarunner's Avatar
Default om617 crank pulley removal Help
I need to remove the alt bracket because its cracked and the crank balancer is in the way of the last bolt. I have the crank pulley bolt out no problem but the pulley seems to be stuck on????
Old Jun 21, 2011 | 09:57 PM
1960mog's Avatar
You have to take the 6 8mm bolts (6mm Allen) out and not the central 18mm bolt ( 27mm socket).
Then you can take the pulley and the harmonic balancer of.
Durin S Day
Sep 12, 2013 09:01 AM
sputnik
Jan 15, 2013 08:57 PM
Schnezza
Jun 25, 2008 04:05 PM
wparker
Sep 28, 2007 10:19 AM
SIMONL380
Jul 29, 2006 07:43 AM
