om617 crank pulley removal Help
I need to remove the alt bracket because its cracked and the crank balancer is in the way of the last bolt. I have the crank pulley bolt out no problem but the pulley seems to be stuck on????
You have to take the 6 8mm bolts (6mm Allen) out and not the central 18mm bolt ( 27mm socket).
Then you can take the pulley and the harmonic balancer of. |
