oil leak
Old Dec 23, 2007 | 08:30 AM
350sd's Avatar
Default oil leak
My 350sd is leaking oil from the exhaust manifold gasket right at the head. Do I just need a new gasket or is this indicative of a bigger problem?
Old Dec 24, 2007 | 11:05 AM
350sd's Avatar
Default RE: oil leak
It definitely is not coming from the valve cover gasket. All clean above the exhaust manifold. I am even getting a little leakage from the gasket that is pre-turbo on the manifold. I guess it's time to get dirty.
Old Dec 25, 2007 | 09:04 PM
350sd's Avatar
What engines would be a match to replace the 350 as far as mounts, trans., etc? I would like to make it as easy (ha, ha) as possible. I said easy because I know it's not cheap. I have two of these rod-benders, lucky me.
orcldba8
Sep 11, 2013 11:06 AM
rx7pro
May 3, 2009 07:45 PM
Buck
Nov 23, 2004 11:16 PM
dadsbenz
Mar 5, 2004 02:19 AM
soaring
Dec 5, 2003 06:32 PM
