No start, cranks only
Old Oct 30, 2011 | 04:31 PM
njm300d's Avatar
Default No start, cranks only
hey my 300d is being a pita, it turns over and the battery is good but it will not start, I realize this is vague information but it is bascially all I know. the oil is at the right level and there is fuel going to the fuel filters. if anyone has had similar experience please provide your insight.
could the shut off be stuck in the off position
Old Oct 31, 2011 | 02:17 PM
njm300d's Avatar
Originally Posted by ForcedInduction
Check the glowplug relay fuse.
Pull the vacuum hose off the shutoff actuator.
Loosen the fuel lines at the injectors and see if fuel comes out when you crank.
Check the air filter for obstruction.
gp relay is semi checked, i've checked parts of the gp system i'll check that next
I have the hose off
haven't tried fuel lines yet
and it wouldn't start with just the turbo without air cleaner (i do realize it's not good for the car)
so if it's not the fuel supply or gp issue i'm going to be stumped
Old Nov 2, 2011 | 09:55 PM
njm300d's Avatar
well i believe the solenoid is a recurring problem as it turns over after hitting the solenoid. how does one know if it is the solenoid or the starter itself? also can something cause the shut off to stick or something in the pump break?
lilcoolaidman
Mar 12, 2009 12:45 PM
94supratt
Oct 2, 2007 11:00 PM
larry89509
Jul 10, 2007 01:47 AM
hrc280
Jul 1, 2007 08:27 AM
LEBEOUF
Mar 14, 2005 11:20 AM
