Knock in upper engine 1982 300D
Old Oct 11, 2016 | 08:49 PM
  #11
konstan's Avatar
Originally Posted by daemdaem
Hello, As I understand the conversation, Your pan is off, but your head is not. To my amazement you have found loose ball bearings in the pan. MM, I happen to have the mate to your engine literally hanging in my shop with gravel inside the broken oil pan. No loose ball bearings, just gravel. I have not pulled it apart yet but you have my attention. I speculate that you may have a roller chain tensioner in yours. The word is speculate. Anyone that has done a complete rebuild know?
How was your oil pressure? Engine Knocks can be tough to find. I would bet you have a loose wrist pin issue. However I have rebuilt a lot of engines and one thing that has saved lots of grief is , checking your bearings and clearances now the pan is off.
Plastiguage is cheap, easy to use and will eliminate a combined knock that is both wrist pin and con rod related.
I ended up yanking the engine out and doing a rebuild. It got all new rings and bearings; one new piston because it had pinched rings which caused piston slap and which probably made the wrist pin loose.
My theory was that the previous owner had a vacuum pump failure which is where the ball bearings are and the ***** ruined the #1 piston.
I have lots of pics of it on peachparts.com, just look for my screen name there... 8 years later the car runs great (I did have a transmission pump failure that I recently fixed -- had to take engine+tranny out again
anthonycocca
Nov 27, 2008 10:06 AM
2006c230
Feb 26, 2008 09:33 PM
Boudreau
Nov 30, 2007 11:58 PM
milo
Oct 25, 2007 07:29 AM
k town benz
Dec 8, 2006 03:42 PM
