Injector Questions
Old Mar 10, 2009 | 06:13 PM
barrylndn's Avatar
Question Injector Questions
When, and if, I decide to replace my injectors on my little diesel (should they be bad, and I think they are), I have read that Monark makes the best replacement. This true?
Second question: in a different forum, of not-so-erudite informers, it was mentioned that the engine would run even better if the pop-pressure was raised on the Monark injectors, and also if you advanced the timing a bit. Is this true? Could it cause damage? What tolerances should i be looking for?
Old Mar 12, 2009 | 09:37 AM
barrylndn's Avatar
Default Ah
Thank you - didn't know if it would damage anything to follow those suggestions, but apparently, it would help. Have you had any dealing yet with the Monark nozzles? All the reviews I've read have been positive, compared to bosch.
Also, ForcedInduction, did you get a "new" car?
Old Mar 16, 2009 | 09:47 PM
barrylndn's Avatar
Default Specifications
Thanks, as always, for your help thus far. I am curious, what is the stock injector pop pressure on the regular bosch injectors, and, more importantly, what is a safe pressure to have the new injectors set at? When I get that done, is there a pressure/advancement chart on how much I will need to advance my injection pump for whatever increase in the pressure I have for the new nozzles? For instance - stock, no modification; 10% increase - how much advance, etc. Is it hard to advance an injection pump?
benz_tweaker
Jan 2, 2006 07:14 PM
JIM
Sep 24, 2005 12:26 AM
w.neurauter
Sep 8, 2005 08:10 AM
Mawbs
Jan 27, 2005 10:02 PM
megamerc
Apr 27, 2004 09:31 AM
