injector pump?
Old Nov 7, 2020 | 02:34 PM
cult colt's Avatar
Default injector pump?
My '81 240d won't start. It lost power and died several times but made it home. I replaced both filters and bled the system because the primary filter had crud in it. I thought that was the problem but now it won't start. I'm wondering if the dirty filter wasn't the real problem. Fuel is getting as far as the injector pump. If I disconnect one of the hard lines from the pump to an injector and crank the engine over there is a weak drip of fuel from the line. How strong should the pressure from the IP be? How can I test the IP/ Thanks for your advice.
Old Nov 8, 2020 | 06:56 PM
JustAghost's Avatar
The tank strainer is probably plugged.
karitoki
Nov 25, 2011 09:02 AM
smaloney1004
Jul 14, 2011 04:55 PM
DaveR
Sep 16, 2007 11:20 PM
khickey
Jun 5, 2007 08:34 AM
gotthebenz4
Nov 6, 2006 10:03 PM
