Heater/AC issue - 84 300TDT
Old Jun 1, 2010 | 08:16 PM
rover1's Avatar
Default Heater/AC issue - 84 300TDT
Just got the A/C charged, and fired it up. I have air from the side vents, but rather than the middle vents, the air is pushing up through the defrost vents. I had the switch panel off above the A/C controls a few weeks back. Could this be a vacuum line issue? Any help is greatly appreciated!!!
Old Jun 3, 2010 | 10:38 AM
cycleboy's Avatar
Yes, it is most likely a vacuum issue. Either a line has come off, or a vacuum modulator has failed.
Old Jun 11, 2010 | 08:24 AM
rover1's Avatar
I am told the problem might be related to a vacuum pod behind the dash. Does this require removal of the entire dash, or just the instrument cluster?
Old Jun 14, 2010 | 10:33 AM
cycleboy's Avatar
Neither. Remove the glove box and the two center vents.
Old Jun 17, 2010 | 09:38 AM
rover1's Avatar
Solved. Vacuum line behind the A/C controls had been pulled loose. Car now stops correctly and the vacuum locks work properly as well.
Vacuum sucks.
rover1
Apr 7, 2012 06:37 AM
ergoa
Jun 30, 2006 03:12 PM
peaceandloveforus
Jun 30, 2006 01:37 AM
tsiero
Apr 19, 2006 10:22 PM
toien
Aug 9, 2004 08:39 PM
