Fuel problem on a '77 300D
Old Aug 13, 2008 | 06:44 PM
F14tomcat5's Avatar
Default Fuel problem on a '77 300D
I have a '77 300D that seems to loose a lot of engine power when I get to a half tank of fuel. The car will run fine until it reaches about a half tank and then it becomes sluggish almost like its starving. Under the hood the rubber fuel lines that run between the injectors/glow plugs seem to have diesel fuel on them also. Any ideas anyone? This is my fathers old car that has been handed down to me. I cant get rid of it and I need to figure out the problem.
Old Aug 14, 2008 | 08:22 PM
lwbrewer's Avatar
Default RE: Fuel problem on a '77 300D
Is it hard to start once it state for awhile? You won't lose power from the return lines JUST $$$
If your hoses are old/ or leakingreplace them all. Once your tank gets that low there's no/little gravity of fuel to the engine and a leak will let the fuel pump suck air. Their are many things it could be. Try a few simple things pull the hose off of inlet to the primary filter hold it below the car and drain into a clean pan. Is it clean? You can blow air back to clean off the screen if their was no flow [ don't over pressurize 5lb max] if it now flows dirt in the tank. Need to drain it and should replace the screen[ not hard] Any fuel leaks need to be fixed. My 87 300d had bad O-rings on the injector pump lines to the injectors and it did not like to start quickly if the nose was up hill, sat for awhile, or had a low tank level. Cheap fix [$20]but needed a $50 socket. If any of this doesn't help you should be able to give more info so somebody can help.
87 300D
Old Aug 14, 2008 | 08:35 PM
marcz's Avatar
This can also be an algae issue in your fuel tank. This happened to me in my '83 300D. Do you have a clear prefilter? If so, are there dark bits of algae in it? If so, you may have algae in your fuel tank that is also clogging the screen in the tank. What I have done is used Biobor to kill it but you need to be ready to replace your fuel filters. I have also drained the fuel tank, removed it, and had it steam cleaned by a radiator shop. Then, replaced the screen.
Old Aug 14, 2008 | 09:41 PM
lwbrewer's Avatar
Yes alge is a bad one you saved a lot of filters and work cleaning yours that way. Had that problem on one of my seldemly used tractors.
ABeardedMan
Oct 1, 2014 12:35 PM
F14tomcat5
Nov 4, 2008 06:36 PM
KANEGRANT
Dec 30, 2006 02:45 PM
jdorencc
Nov 18, 2006 05:27 PM
kazacs
Sep 22, 2005 05:42 PM
