Electrical
Old Dec 12, 2007 | 06:44 PM
rodmo1's Avatar
Default Electrical
Although not directly related to the diesel engine I am having trouble diagnosing a turn signal inop problem on my 84 300sd. Basically yesterday I checked my fuse box to figure out why my dash and console lights are not working when all the fuses were verified as good I closed the box and now my turn signals no longer work. I then swapped out the relays and still nothing. My horn does work which I am told is on the same fuse/circuit. Anyone have any ideas??
Rod M.
Old Dec 13, 2007 | 10:55 AM
Drrty240D's Avatar
Default RE: Electrical
Did you physically remove the fuse in question from the fusebox to check? Sometimes these ceramic fuses show good with a tester or test light, butwhenyou remove them from the fusebox the conductor stripfalls apart. Also check your chassis ground in the engine bay. It should be a 10mm bolt attached near the front fender with a bunch of brown ground wires bonded to it.
snglbrd
Dec 11, 2004 04:47 AM
jwnpgh
Feb 9, 2004 09:11 AM
JayJay442
Jan 23, 2004 12:32 AM
SteveNihan
Dec 5, 2003 08:16 PM
