diesel cylinder sleeves
Old Dec 30, 2010 | 09:54 PM
felinervmd's Avatar
Default diesel cylinder sleeves
Help anyone who has done this? Have a 300dturbo, pulled head #4 wall scored and head needs to be done.Early search indicates a puller$$ etc. Is this a DIY
for a non machinist? Thanks Ron
Old Dec 31, 2010 | 02:02 AM
Diesel9112's Avatar
You might be able to make something to pull the Liner out but shops often freeze the liners in Dry Ice and install them really fast in order to get them in.
The installation part is not something you want to start without having the right tools because if the Liner gets partway in or goes in at an slight angle you will need the right tools to finish the job.
Not on Mercedes but on other Diesels with liners my Boss had a Steel Tubing with an Id large enough for the Liner to pass through. A Plate was made for the bottom to grip only the liner and threaded Rod with Nuts on each end. There was also Plate that went on top of the Pipe with a Hole in it for the Threaded Rod to pass through.
mercedesdieselpetr
Jun 28, 2017 06:14 PM
JTORRES
Apr 16, 2011 11:38 AM
Malanena
Feb 25, 2009 05:46 PM
thommo 1
Feb 2, 2009 02:50 AM
samo
May 17, 2005 05:32 AM
