CAR WONT SHUT OFF!!!!MBZ 82TD
Old 11-06-2007 | 08:17 PM
spicybabes's Avatar
Default CAR WONT SHUT OFF!!!!MBZ 82TD
I had the oil & filter change by a friend and when I wanted to turn offthe ignition, it wont shut off. Does anyone know anything about this problem and help me resolve it???? Thanks
82 MBZ TD 247.000 Miles
Old 11-06-2007 | 08:38 PM
Its_Puddin!'s Avatar
Default RE: CAR WONT SHUT OFF!!!!MBZ 82TD
Yup - right above where the oil filter goes, there are vacuum lines. 1 or more are disconnected. Reconnect them. Pretty common.. you need to be careful when doing the oil change.
Old 11-06-2007 | 11:35 PM
spicybabes's Avatar
Thanks very much..its_puddin! yousaved me from having nightmare about it...I will be checking the lines tomorrow. Again thanks
Old 11-07-2007 | 04:32 AM
joe4324's Avatar
I bet he is correct, That big mess of lines right near your oil filter is almost entirely vacuum hoses if it is anything like my 84 300D, Even one of those little lines being leaky or unplugged can be a pain. If you didnt know, on your throttle-linkage you might have a large red "STOP" sticker, just push it and it cuts the fuel and kills the engine.
Also, if you want to get specific, I believe there is some type of vacuum powered pump? on or near your injector pump close to your oil filter. It might be clear (mine is clear/green) and the throttle linkage eventually makes it to this unit, That part has a vacuum line that provides the suction that cuts the fuel off when the car ignition is turned off, you can start there and back-track to find your disconnected vacuum line.
Sorry if this was confusing! good luck!
kalebfrog
08-20-2014 05:29 PM
catman
01-03-2009 06:31 PM
joe4324
11-09-2007 08:55 AM
srishell14
07-06-2007 02:59 PM
ClkE
06-02-2005 05:09 AM
