Tough starting
Old Oct 23, 2007 | 07:05 AM
AMGMercedes's Avatar
Default Tough starting
84' 190D has a tough time starting. It's got new fuel filters, a new glow plug relay and new glowplugs. Also the glow plug indicator on the dash glows before restarting. Any help would be appreciated because I'm about to call BS on my mechanic who supposively changed the plugs in July
Old Oct 24, 2007 | 12:10 AM
Grateful's Avatar
Default RE: Tough starting
It's possible they put in cheap glow plugs that could have failed by now. I'd check resistance and confirm plugs conditions.
Old Nov 7, 2007 | 11:38 AM
howardjnl's Avatar
Went through similar issue on '87 300TD. Glow plug light lighting up as normal, but running he battery down trying to start the engine. Replaced glow plug relay to be sure, plugs measured "good", no obvious electrical problems, still no fix. Found a very small crack on a rubberhose fuel line feeding the first fuel filter, replaced the hose, starts right up after "glow".
KenF
Dec 5, 2007 09:50 AM
Red5
Jun 8, 2007 11:15 AM
hendrix
Jun 29, 2005 06:13 AM
stingray380sl
Nov 4, 2004 10:23 PM
john5
Jan 28, 2004 08:58 PM
