can i replace the starter solenoid only
Old Oct 19, 2009 | 08:51 PM
mmmcheechy's Avatar
Default can i replace the starter solenoid only
I cleaned all my battery wire cable ends and battery + and - posts today. When i put everything back together and turned the key i got nothing. The battery is fine. I checked the starter by using a jumper cable to bypass solenoid and it turned over. Also noticed that when i was tightening the positive lead to the solenoid that the casing was loose. a side question~would a bad solenoid prevent the clock from working? Thanks
Old Oct 20, 2009 | 12:21 AM
Diesel9112's Avatar
You can indeed change only the Solenoid. However, there is another test missing and that is to jumper a posative from the battery to the Solenoid Terminal. If the Solenoid does not engage that could indicate a solenoid problem.
It would have been nice to know what year and Model you have.
On mine there is a wire Junction Block in front of the Battery on the Fender Well that you can use with a short Jumper Wire to test the starter.
Yours may not have that or have it located somewhere else.
If jumper wiring the Solenoid works you most likely have a Netural Safety Switch or Ignition Switch Problem.
I thought the Clock ran all the time so I dought if it is wired to the Starter but I cannot say for sure.
JRR4948
Oct 18, 2011 09:06 AM
alex_22289
May 1, 2011 05:29 PM
Ichief
Nov 9, 2010 12:24 PM
silverhalide1
Jul 21, 2008 02:44 PM
crit1
Mar 28, 2006 04:32 PM
