Aux fan always on -350SDL
Old Jul 20, 2008 | 06:53 PM
paul060266's Avatar
Default Aux fan always on -350SDL
The auxillary fans come on at about 82C and stay on without the a/c on. Temp ranges between 85-90C. This has happened even in the winter (Michigan).
New thermostat (80C), radiator cap, proper coolant, fan clutch, fan, hoses. Radiator looks good without any damaged or broken fins, no weeping at the water pump. New aux fan sensor and temp sensor.
I assume that this is not normal...any advice would be appreciated.
Old Jul 20, 2008 | 08:04 PM
sundaynsonz's Avatar
Default RE: Aux fan always on -350SDL
did you check your fan clutch ?
Old Jul 21, 2008 | 07:29 AM
paul060266's Avatar
The fan clutch is new. What should I be checking for..?
Old Jul 22, 2008 | 12:30 AM
one way to check if your fan clutch is working properly is when your electric/aux fan kicks in..your fan clutch should be working this very moment...meaning your fan should begenerating good volume of air...if not this explainswhy youraux fans are working overtime. Good luck
Old Jul 22, 2008 | 07:10 AM
paul060266's Avatar
Yes, the clutch fan is working fine. When I shut the engine off it is difficult to rotate as opposed to when the engine is cold and it spins fairly easily.
Does anyone know what temperature the aux fan should come on with the a/c off..?
Old Oct 11, 2011 | 04:45 PM
rommel2517's Avatar
Default Auxillary fan always on '89 300e
I have an '89 W124 300e and my auxillary fan turns on even when the engine is still cold when I turn the ignition key on or start the engine. Hope someone can help me with my problem.
Old Oct 12, 2011 | 04:28 PM
rommel2517's Avatar
The a/c is not even on and its still running. Once I turn the ignition on it will not stop until I remove the D fuse.
Old Oct 16, 2011 | 12:03 PM
hapaschold's Avatar
that happened in my 77 450 sl, replaced one of the sensors by the manifold and all was good..
i think the water temp also turns the fans on in the sdl......but they do come on when the ac is on in my 350sdl also......
ip650123
Jun 16, 2011 11:02 AM
Tcheairs
Dec 20, 2010 09:56 AM
rwhigg
May 5, 2010 09:56 PM
paul060266
Aug 19, 2008 01:21 PM
haidarsaid
Jan 22, 2005 11:51 PM
