87 300D glow plug problems
Old Nov 24, 2012 | 11:56 AM
oldrebuiltdodge's Avatar
Default 87 300D glow plug problems
Hi there, My 87 300D suddenly decided to burn out the fuse strip in the glow plug relay. I don't have a wire diagram to see if I can find out why. I changed the glow plugs a little over a year ago, and it hasn't had a problem since then 'till last night. When I pillud the cover off of the relay, I could see traces of lots of heat, like it was a direct short, or it stuck in the on position, and overheated. Can anyone help me out with a diagram? Or does anyone have any ideas where I should start looking? Another question is what is the amp rating of that fuse strip, so I can replace it with a fusable link.
Old Nov 25, 2012 | 05:53 PM
Thanks I have tested he glow plugs, all are good, the controller is on order it wasn't as expensive as I expected, I'm still going to look nto possibly repairing the old one, because they might not be so readilly available later on. I intend to keep and drive this car 'till repair isn't possible any more.
Old Dec 20, 2013 | 09:39 PM
Friedolin's Avatar
Default 87 300D glow plug problem...
"...they might not be so readilly available later on. I intend to keep and drive this car 'till repair isn't possible any more."
I love your attitude! :-) I have an 87 300D Turbo with 256,000 miles on it and I too want to keep it as long as possible. (It most likely will outlive me as I am 84.) :-)
Last week I made a one-day round trip from Atlanta to Florida (Yalaha), all total about 800 miles. With the cruise control set at 80 mph I averaged 28 mpg. The car and the engine still run like new. :-)
About glow plugs: If I am not mistaken, the timer keeps them hot for about 20 seconds. By NOT cranking the engine for 5 seconds after the glow-plug light goes out, it will start almost immediately every time, even on cold days. :-)
Uber Monger
Jan 4, 2011 07:23 PM
stevenkd5017
Oct 20, 2009 07:53 PM
Cantukeeslim
Jun 4, 2009 01:06 PM
duresmith
Jun 10, 2008 10:43 AM
threehunde
Mar 21, 2006 11:14 AM
