87 300 SDL overheating
Old Aug 5, 2009 | 06:12 AM
trogmaster's Avatar
Default 87 300 SDL overheating
Without a/c on the temp stays constant 80C
With a/c on temp bounces between 85-110C. Mostly 110C
Just replaced clutch fan with OEM Behr and a new belt
Could the t-stat be the problem?
Any help would be appreciated. thanks
Old Aug 5, 2009 | 04:45 PM
trogmaster's Avatar
Originally Posted by Forced Induction
Sounds like the electric fan is not coming on. It should kick on when coolant temperature hits 100 or the A/C freon pressure gets high.
Stop letting it get past 100! The longer you let it run that hot the far more likely you are to crack the cylinder head.
Just had the a/c serviced by electronic machine at dealer. So don't think
it's that.
Pusher fan comes on when car is started. ?? Maybe relay bad when gets hot. What is in the circuit and location(s)?
May put on an aftermarket fan, 2000 cfm and tap into re-circulation circuit.
Then turn on when needed
gugufut3
Jul 3, 2007 11:32 AM
mike0
Mar 30, 2006 11:46 AM
aquaman
Nov 11, 2005 08:05 PM
rudygazza
Oct 20, 2005 03:01 PM
ATL8
Jul 22, 2005 04:53 PM
