87 300 SDL overheating
Without a/c on the temp stays constant 80C
With a/c on temp bounces between 85-110C. Mostly 110C Just replaced clutch fan with OEM Behr and a new belt Could the t-stat be the problem? Any help would be appreciated. thanks |
Originally Posted by Forced Induction
(Post 124746)
Sounds like the electric fan is not coming on. It should kick on when coolant temperature hits 100 or the A/C freon pressure gets high.
Stop letting it get past 100! The longer you let it run that hot the far more likely you are to crack the cylinder head. it's that. Pusher fan comes on when car is started. ?? Maybe relay bad when gets hot. What is in the circuit and location(s)? May put on an aftermarket fan, 2000 cfm and tap into re-circulation circuit. Then turn on when needed |
