87 3.0 not shutting off
Old Sep 20, 2006 | 09:10 PM
SEmerson's Avatar
Default 87 3.0 not shutting off
I have a 87 3.0. Turning the key off will not shut it off. The lever will almost pull down enought. I hooked a vacuem pump to it and I can suck the lever down but it leaks bad. I am thinking there is a hole in the diafame. Is that all it can be? It is a major job to get the top off the pump so I want to know there is no air bleed or anything like that before I go to all that work. I also don't have heat contols in the moring. I also beleave it to be a vacuem leak But unrelated to the shut off probem due to the hand help vacuem pump i put on the engine. Any help would be great.
Steve
Old Oct 9, 2006 | 11:34 AM
pgf300TD's Avatar
Default RE: 87 3.0 not shutting off
Check out dieselgiant.com for step-by-step instructions on how to change the vacuum operated shutoff switch.
phyberlink
May 3, 2014 08:45 PM
Don's ML
Jul 26, 2012 10:25 AM
GARY476
Jan 20, 2010 07:46 AM
bootsie
Sep 18, 2009 08:09 PM
rcrochet
Sep 30, 2008 07:23 AM
