85 300D transmission not shifting
Old Dec 30, 2008 | 04:13 PM
boblo_home's Avatar
Default 85 300D transmission not shifting
The transmission is not shifting. It starts up in 1st and reverse OK but will not shift into 2,3 and 4th. What could be wrong?
I have changed the followings:
1) Transmission filter and fluid
2) the solenoid inside the transmission from a junk yard.
What else can be wrong, Vacuum, modulating valve? I do not know transmission well and do not find any info in my Haynes manual. Your advise is appreciated.
Old Dec 31, 2008 | 03:52 PM
Drrty240D's Avatar
Default RE: 85 300D transmission not shifting
Topic discussed many times on the forum, use Search to view old discussions. Your trouble is likelyrelated to vacuum - checklines to modulator and check modulator itself for proper operation. If the modulatorhas not been changed in 100K miles, or if you've never changed it go ahead and put in a new one.
frk203
Jun 22, 2008 04:45 AM
KeithinKentucky
Apr 17, 2008 03:25 PM
redly1
Sep 2, 2005 07:01 PM
gte811f
Aug 7, 2005 02:37 AM
cool
Oct 29, 2004 10:44 PM
