350SDL--Is this the beginning of the end?
Old Nov 11, 2006 | 06:49 PM
mbenzer's Avatar
Default 350SDL--Is this the beginning of the end?
137,695 miles
I have had to add small amounts of water to the reservoir at least twice now in the past 2 months whenever the dash light came on with no discernible/visible leakage. When I first start the car, it runs rough as I depress the accelerator 3 or 4 times with white/blue smoke coming from the exhaust. After that, it levels out and runs smooth. There is no appreciable oil consumption. I'm due for an oil change now in 3K mile intervals and it's barely down a 1/2 quart. I went through a month or so this summer running hot (about 105-110C) until I had the replacement radiator replaced. I would say that the engine never technically overheated, i.e., never redlined during that period. I detect no water in the oil on the dipstick. The right front corner of the engine is wet with oil well below the valve cover but not at the valve cover. Could this be small amounts of water seeping into the first cylinder because of a warped head? Am I headed for hydraulic lock and a bent rod?
Old Dec 4, 2006 | 11:52 PM
dieselsteve's Avatar
Default RE: 350SDL--Is this the beginning of the end?
HEAD GASKET- change the head gasket ASAP!!!!! I had it go on mine too!
Diesel Newby 81 300D
Dec 6, 2010 04:44 PM
vince_xu
Sep 24, 2008 09:05 PM
mbenzer
May 16, 2005 04:38 PM
mbenzer
May 15, 2005 11:22 AM
