300D vacuum modulator question
Old Oct 9, 2007 | 03:54 PM
rdharper's Avatar
Default 300D vacuum modulator question
1984 300D... harsh, late shifting all shifts.
Newly aquired, so I'm waiting for the FSM to get here (ups says the 15th).
In the meantime I've checked the vacuum pressure just before it goes over to the passenger side and apparently down to the transmission. Reads 15 inches HG. Nicely goes to zero with momentary WOT.
After reading these forums (thanks guys), I'm expecting to find the modulator at the transmission, where the vacuum line apparently goes.
If I recall correctly, a half turn counterclockwise should give me a softer and earlier shift... the logical next thing to try. I may pick up a longer tube for the vacuum gauge so I can read it while driving.
So I need a sanity check here... does the above make sense and the logical next step?
Old Oct 10, 2007 | 07:41 AM
Mr.47's Avatar
Default RE: 300D vacuum modulator question
what do u adjust to make it shift smoother, is the white looking screw you adjust or under the transmission with the T key?
fredwho
Jan 24, 2014 01:50 AM
johnrolf
Mar 3, 2010 03:48 AM
Johnnyrat
Jul 11, 2007 10:22 AM
sppcartons
Jun 17, 2005 11:13 AM
tbailey
Nov 16, 2003 02:27 PM
