300d 5 cyl 1988 in hymer s660 help!
Hi
I bought this motorhome last year and it ran beautifully all year
Since waking it up after the winter it is not so good
Initially it would misfire when cold and be back to normal once warm
Tracked it down to air in fuel line
Replaced all return lines on injectors, new filters thought that was it
No it still is mifiring and seems to emit whiter smoke when spluttering
It starts on the button and heater plugs and relay are ok
Any help greatly appreciated as to where to go next
73k miles on clock
ps Seem to have sorted all fuel line problems but can see air in return line from injector pump to fuel cannister when revving engine. Is this normal?
73k miles on clock
Thanks for the reply
Already tested glow plugs - all fine
am leaving in to garage for full check on fuel lines as I need to get it sorted fast for holidays
Will let you know how I get on
Seamus
Seamus
I left in my old Hymer to my local mechanic who is an ex mercedes trained mechanic and I am glad I did.
It turns out I had sorted all air issues but I had not realised there was another fuel filter in canister at engine.This he said was quite dirty so He started there and on next cold start up still had misfire. He then went on to injectors and found no 5 not firing. He pulled all the injectors an on test found no 5 ok but no 3 not up to scratch. He then came to the conlusion that the tappets were getting tight so adjusted them with no 5 being tightest leading to exhaust valve staying open. i am getting her back today and unless valve seating on 5 is damaged I should have a much smoother and more powerful engine back. Some things are better left to the experts! Dont know what cost is yet but whatever I hope it runs well !!
funkykeys1
May 28, 2007 11:43 PM
edwardwright
Jan 5, 2005 12:23 PM
