300 sd losing locking vacuum
Old Aug 11, 2015 | 07:15 PM
pekingnesepuppy's Avatar
Default 300 sd losing locking vacuum
my 1984 is losing central locking vacuum. now only the driver's door will open.
is it a fuse problem or is it a vacuum pump problem?
thanking in advance for any help or advice. - francis
Old Aug 12, 2015 | 11:36 AM
dreamer no2's Avatar
You may have a vacuum leak so you need to get a vacuum tester and try all you lines, start under the bonnet . Or even the pump is leaking check all the little rubber joints,and elbows, and connections for cracking .
Old Aug 15, 2015 | 07:27 AM
thank you mr forced induction. - francis
Old Aug 15, 2015 | 08:54 AM
Jusat to add that if the one door is opening then the fuse will be ok, and the fuse will be in the fusebox under the hood .Pump location behind the trim on righthand side the trunk
vlubrano
Dec 2, 2010 07:46 PM
grizzly_b
Jul 15, 2009 01:28 AM
delboy277
May 12, 2009 05:19 AM
ramses
Sep 19, 2007 03:45 PM
