240D Automatic Transmission questions
Old Feb 26, 2007 | 09:24 PM
ajrn's Avatar
Default 240D Automatic Transmission questions
Was going to change the tranny filter/fluid in my '81 240D.. Doesn't smell burnt, but OH MY does it look awful.. I figured maybe there's still time to get the nasty stuff out of there before it hurts something..
I'd see the diesel giant 'to do' file..
I was underneath, assessing HOW far gone my exhaust was-- and thought-- Hmm, I could drain the fluid from the plug NOW-- re-add fill it, and drain it again, when the filter arrives later this week.. But UGH-- doesn't look like there's a pan drain on my tranny-- are there some without it??
If that's the case-- is there an 'easy' way to drain the torque converter??
I want to get as much of the old (probably been in the transmission since BIRTH) fluid out, as 'reasonably' possible. I don't really feel like dumping $100 into having it "professionally" flushed, either.. Still would have to get underneath, to change the filter.. Can't imagine changing fluids, and leaving the filter..
Old Mar 1, 2007 | 01:03 AM
amberolaman's Avatar
Default RE: 240D Automatic Transmission questions
ORIGINAL: ajrn
Don't bother messing with it until you're ready to do the whole job.
In many automatics, you drain the fluid by slowly dropping the pan, leave a bolt or two in the front or back of the pan halfway loose, and pull the rest, letting the pan hang down. You'll need a rather wide drain pan.
My older Benz'z have a banjo bolt that holds the dipstick tube on, that is a good place to start draining the trans if you have that setup.
The torque converter has a drain plug, you have to rotate it around til you see it I believe it takes a small allen type socket to get off.
If you change the fluid and filter every 20 or 30 thousand, most automatics will last a very long time
Old Mar 1, 2007 | 01:18 AM
ajrn's Avatar
Thanks--
I knew the pan drop technique.. I didn't think about using the banjo bolt though.. That sounds like a pretty slick plan..
...ANY idea of what the refill capacity is-- if I drain the torque converter?? I'm assuming 6 quarts, as a start point.. Then a half quart of at a time, till I met the marks..
ESGatch
Aug 13, 2014 02:42 PM
ESGatch
Mar 14, 2013 08:04 AM
Sailing131
Jul 31, 2008 09:39 AM
rohitsagar
Apr 14, 2007 02:17 AM
drujinin
Jun 22, 2005 11:04 AM
